87 Lower intake, powder coated with stainless water housing.
D's GN
I have a 87 lower intake which has been powder coated natural aluminum, it has the EGR filled and the runners are ported. It comes with a coil pack bracket, EGR block off plate and a Stainless Steel water neck already installed. This is a great deal at $260.00 shipped
The price is very reasonable. Most intakes run about $150-175 get one powder coated that will run $60-$80
SS water neck $30 bracket another $20. Then you have the EGR blocked off!
100% agree with you !!! Had to try !! I dropped off mine to get done. I will get estimate this evening. Will let you know later if I'm in the running for yours . Much appreciated , thanks
Thanks! Unfortunately the runners are not ported to a 1200 gasket, they were ported/cleaned up by a local cylinder head pro and he also filled the EGR. This cost me roughly $100 a few years ago. I may keep it if it doesn't sell at this price. The intake will support airflow for 9 sec power. My quickest pass was 10.30 at 22 lbs a couple years ago before I upgraded to ported gn1heads and a bigger turbo.
