Ed Salsbury
- Nov 30, 2015
Hi Guys,
Appreciate the forum, great job!
Man, I'm stumped and frustrated, need some help, as I'm only backyard mechanic, if that......
I recently bought 87 Turbo T, 135K, Greedy Blow off, car had sat for 8 months, w/ 1/4 - 1/2 tank gas, started by previous owner only occasionally, no dash idiot lights, just washer fluid, and occasional brake lights, rpm gauge stuck mid way, boost gauge started working just now and seems fine
My problem (s), the idle is pretty high, and car has bad hesitation after acceleration and let off, must feather pedal or WOT to bring it back up, so....
This morning I changed all the plugs CR-43TS .032gap, (the pass side one by firewall was a MFer, dont know when that was last changed), new 8mm silicone wires, can of Berrymans B12, 10 gals new gas. So far after driving around town for 90 minutes and many WOT bursts, seems to be better, but still there, car will idle fine, although still high, and while parked will bring rpm's up instantly, no problem while in neutral, car accelerates at WOT like crazy with hard 2nd gear chirps, but again, after leveling acceleration off, and lightly touching it again, man, bad hesitation with occasional popping. I disconnected MAF and started it up, took test ride, no change, still same high idle and hesitation, but WOT is great.
I don't want to be a parts buyer, but thinking of fuel filter, new MAF, new coil pack??
Any help is greatly appreciated, thank you in advance
Ed
Ed
