They wll as long as you change the gear every 30 passes to be safeDwayne at a certain performance level I am not sure the 8.5 gears will live.
Most of us won't get there though!
drop in bleed brakes and drive
Here ya go.
Those are standard 2.5" id coil over springs. QA1 is the brand. It's a trick I learned over at maliburacing.com. They really open up your choices on height and spring rate.
Most aftermarket 9" housings have extended spring perches on the axle tubes so there's no worries with the spring falling out.
Mine are 12" 170 lbs.
There is definitely a 3-4" gap on top when the car is jacked up. But I don't have any issues with them falling out or not seating correctly when the jack is lowered.
I did a Moser M-9 Bolt In Upgrade...Everything bolted up fine. The width and backspace on wheels worked out great, fit just like the stock rearend. I have a backbrace, 35 Spline Axles and 5/8" Studs. Over Kill for my combination but I got a deal on complete unit. I added a Strange Aluminum center section with a Detroit Locker and Wilwood Disc. I also changed the stock driveshaft in for a Aluminum Unit during the change. Definitely a nice upgrade for our GN's...
Scott,
I looked on the maliburacing.com website and found a moog spring part # 5391 which has a free height of 15.4 inches. My stock springs are 14 inches free height. I believe these might be a station wagon spring. They are stiffer but they give me the extra free height that I need to give some preload on the spring seats. I'm not sure what they'll do to ride height though.
George
Don't take this the wrong way, but that is the nicest rear end I have seen
in a while...
George. Try a 14" 130# spring for starters. These QA1's are cheap and if they are not what you need, you can return them and get something else. I run the 14" 130 on my car but I have seen a few with 14" 110-120 to get the ride height correct.
You would have to run a very tall spring with a light rating to achieve what you are looking for. If that's your ultimate goal then look into a 16" spring with a 90# rating or so. You can even call QA1 and they can direct you to what your looking for. They can better advise you on if that spring will work or if the rate will be to light.
My opinion is you need the correct spring height to match shock travel which is usually a 14" spring unless you get custom shocks. The shocks should be disconnected from the rear when you jack the car up like you describe anyway and you shouldn't expect the spring to stay in place. I know it's a pain the get everything back into position but the proper spring for your set-up at ride height is much more important than the spring staying in place when the rear is dropped out of position. The lower the ride height, the happier the suspension is and the better it drives.
jevans,
Very nice rear end!
That is what I am thinking about getting.
Just curious on the cost?
Rick
here's a 14 - 110
QA1 14-110 - QA1 Powdercoated Coil Springs - JEGS
and here's the 14 - 95
QA1 14-95 - QA1 Powdercoated Coil Springs - JEGS
here's the 14 - 130
QA1 14-130 - QA1 Powdercoated Coil Springs - JEGS
jevans, could I get some info on that too? I'm going to need to do something soon. TIA
Rick
