So i started up the gn on sunday, and while she was warmimg up I kept hearimg a clicking on and off of a relay. Popped the hood and I saw that it was the AC clutch engaging and disengaging on and off every three to five seconds or so. The AC wasnt on inside the vehicle. Is this normal?
It gets better. About 2 minutes go by with me staring at it to see if it stops when she warms, up and BANG...CRACKLE....SNAP, the serpentine belt disappears into the engine compartment. I shut her down real quick to investigate and notice that the PS pump has been torn off by the mishap. I further investigate to see that both of the PS mounting bolts must have come loose (or were never properly tightened). One of them was fine, but the other was broken off in the bracket.
My question is, I was checking the rotating resistance of the AC compressor by grabbing the clutch on the front and turning. It seems to rotate with quite a bit of force(probably a few ft lbs). The pulley itself rotates freely on the clutch. Is this normal? Is there a decent amount of resistance in the compressors rotation? I ask because I am trying to figure out if the belt throwing mishap is related to the compressor starting to freeze up or something, or if it was just negligence on whoever was last supposed to tighten those PS bolts.
Luckily there was no damage beyond the PS bolt breaking and a few small knicks in the intercooler fan.
Anyone have any input on this?
