Hi all,
I'm trying to find the location of the check valve that keeps vacuum in the lines to the A/C vent doors under the dash when you enter boost mode.
Anytime I go from vacuum to boost readings, I get hot air blowing through the vents. I've been told there is a check valve (not working) that keeps vacuum in the lines, kind of like the vacuum check valve on regular brake systems.
Does anyone know where it is or what it's called? We can't find it in the GM parts book.
Thanks - Terry
Thanks - Terry
