A aze12677 Member Joined Feb 27, 2005 Jun 28, 2008 #1 what is the temp of the air should be coming out the vents with ac on max with 132a
8 87lightweight New Member Joined Aug 16, 2007 Jun 29, 2008 #3 i would probably post somewhere else than the for sale section, might get better help :wink:
P Preston87GN New Member Joined May 24, 2008 Jun 29, 2008 #4 between 38*F-45*F would be sufficient but this can go up if you are in a extreme heat climate.
