hi
i have a 84 t type with air my gauges read it is full of 134
my problem is the compreser come on for about 10 seconds then stops for about 10seconds it will do that all day does anybody know how i can fix it.
thanks harold
hi
thanks harold
Well it sounds like an easy fix, but I take it that all you have is one of those auto parts freon charge hoses that say full or empty........not accurate at all. Chances are you are low on refridgerant which is why the compressor is cysling so much. If you had guages and could tell the point at which the compressor cycles off it could very well be that the low pressure switch may need adjusting. These are just possibilities as Charlie has asked, if you don't have gauges hook up to the car there is really no concrete answer.
