Hey Guys,
First off, I have a couple of cars with the same strange miss problem. Both cars have set ups similar to the sig below with one having ported iron heads. The car with stock heads seems to miss at high boost (25+ lbs) and DS shows that they are single frames at 18.2 fps. They are NOT MAF related as the MAF does not fall out as it used to with every miss. The ported iron head car does the same thing but at any boost level. DS shows on both cars the injectors being turned off for a single frame and then coming back on line. LV8 seems to be the most common variable to cause the miss but what is causing the LV8 to drop?
Another thing...if I park my car on an incline with the passenger side higher than the driver's side, the car will not start. I have to clear flood the car and floor it when starting like an old carb car to get it to start...anyone know why?
TIA,
Kev
TIA,
Kev
