So when guys are tuning for meth,,,, when just running the engine w/no meth injected, are the engines A/F ratio ,say about,just for example 11.2 - 11.8 & then inject meth & richen the mixture to 10.0 - 11.0 range?
Do guys make there A/F ratios really lean ,say 12.5 - 13.0 or leaner w/no meth,then w/meth injected,richen the mixture to 10.0 - 11.0 range?
Hope that makes sense.
This way the engine could run more boost,but if anything went wrong w/the meth inj,the engine would most likely break something. Like a piston
I use a J&S safegaurd,that really works good & helps prevent the engine from detonating.
For basically semi stock Syclones running pump gas Nolan
http://www.campbellautomotive.com/1000hpv6.wmv
likes to tune the Syclone A/F ratio to 10.8,any leaner while boosting more than stock,he says the engine would tend to detonate.
I know my engine liked to run good w/a A/R ratio of 10.8 - 11.0 on pump gas.
