adjusting fuel pressure... well knock problem
chumanga
ok not sure what this is related to but im guessing its fuel pressure or maybe bad fuel... when at idle o2 volts go from .300 to 700 when i drive around slow its fine but when i start to give it gas the o2 volts will drop to like 100 if i hold it they will start to go up to 400-600 if i get on it a lil hard the retard degrees will go to like 15, i let off imediately and they will go to 0, one time when i gradually slowed down it went from 15 to 2 and then to 0 was at 2 for a short bit but i wasnt completely off the gas. is this a fuel pressure problem, fuel quality problem or any ideas???
thanks
Lance
