air con compressor - which fits our TR
channer
Hi
I don't know if all air conditioner compressor are the same but if they are not... which vehicle use the same air con compressor as our TRs,
thanks... dave
Hi
thanks... dave
Early 90s Camaros and firebirds. Not sure which models but you'll know by looking at them... serpentine pulley the same size as ours. They're a bolt on.
If you do end up using one of these make sure you clip the wire connector off with it. Somewhere around 88-89 GM started using an improved weatherpak style connector on the clutch. No big deal. Just splice it onto you existing wire harness.
thanks for the replies...
Just thought... what about the compressor from the 90's LT1 Caprice/Impala/Buicks? There seems to be more of the around in the wreckers than Firebirds and Camaros
dave
dave
Pulley is not the same ... smaller diameter. And as Eric mentioned, take the plug connections.
LT1's use the funky HD-6 compressor. If you're thinking L03/L05 TBI SBC than as John said the pulleys are different.
