It doesn't seem to be blowing cold. I think I read somewhere that most people have/are converting to a different system (R134a?). I'm not sure what I should check first... any ideas? Pretty sure I have the stock setup. Also, when the A/C is on the car seems to surge (idle higher) every 5 seconds or so. Any Ideas?
		 This would know more. bill at auto kool systems 630-834 -0614.
 riginally it was low on R12 refridgerant.It was switched over  in the fall.By the time I took the car out in the spring, it was low again.Had it refilled again.Three weeks later low again.This is getting expensive by now.The mechanic who refilled it said the molecules on the R134a are smaller than the R12.He said he could not detect a leak anywhere with the black light test.It must be leaking alot to empty in three weeks! He said I would probably have to keep refilling it,and that my compressor might have a leaky seal.My question is for those low on R12 refridgerant.Wouldnt it be a waste to switch over to the R134a because its gonna leak out anyway with the smaller molecules? I want this fixed.I'm probably gonna have to replace the compressor and start all over.Not looking forward to the bill.
