turbofabricator
- Mar 7, 2004
Ok guys I have finnally got the Buick running. I had a great time at TT, and wish I could have made it in my car. It was great seeing you guys (and gals) again. The car is an 87 T-Type with :
Girdled 109 block
stock crank/rods
TRW pistons w light pins
Twin stock turbos (new)
Twin stock throttle bodies (common shaft)
Twin Stock intercooler cores
6 Alky nozzles in plenum
Alky Control pump and controller
Ported iron heads (by me)
ported stock lower intake
fabricated upper plenum
321 stainless steel I/C tubing
321 stainless lower rad hose
218/224 hyd roller
1.6 roller rockers
wastegate in cross-over pipe
60 lb Motron injectors
Maf Pro (no MAF)
Extender Pro chip
stock ECM
Art Carr 3600 nl
battery in spare tire well
There's a TON of work that can't be seen but now the real work starts as in tuning. It should run a 16.5 @79 but might take me awhile to get there :tongue:
Ken B
"Happiness is Alcoholic Twins!"
Girdled 109 block
stock crank/rods
218/224 hyd roller
1.6 roller rockers
Maf Pro (no MAF)
Extender Pro chip
stock ECM
Art Carr 3600 nl
Ken B
