i dont see why it wouldnt work as a pre-spooler. your injecting it into the engine anyway, so why not inject onto the blades? if you focused the spray at the smallest part of the compressor housing, tangent to the blades, it would create quite a bit of rotational flow. a good way to experiment would be with a shot or sacraficial compressor housing. take a whole turbo to a bench and try different mounting points. if you could get some decent spool with just the propane, it would be very beneficial.
just a thought
just a thought
