Everytime i go under a decent amount of boost. I get oil sprayed on my downpipe from the turbo return feed at the grommet. Has anyone got any tricks to seal this up? And is it safe? Does anyone else have this problem?
Several things could cause this. The turbo oil drain pipe could be cracked, grommet is shot, or high pressure in the block is keeping the oil from draining. The latter can be cured by using a valve cover breather. Let us know what you find. Brad
