Jerryl
Tall Unvaccinated Chinese Guy
- Dec 14, 2004
Hey Pat,
Some good continued work and some GREAT collaborative discussions going on here.
Are you testing the port flow under vacuum or pressure?
IMHO, if the testing is performed under vacuum, there is a flaw in the set-up.
The intake on a boosted application should be tested lik a an exhaust post, especially in a poorly designed manifold.
Is there a way to take a ported intake and compare the flow numbers of a couple of ports under vacuum and pressure?
Edit:
General statement;
The ported stock intake has been 10's and is NOT the system constraint with a TA33 or TA49.
Edit:
General statement;
