Have you contacted dave husek?
CK still makes the billet forward drum and input shaft, and those prices seem very fair.
Can't find billet planetaries for the 200-4r, might be a case of no demand if they don't really break and no one offers them. Monster Transmission offers a ton of parts but didn't seem to be billet or 4340 etc.
Trans Pan, that seems practical if nothing is available. Make the flange then either make the pan a separate piece or fabricate from a pro.
CK may make it but they don’t have it.
So I'm sending him my ported heads and intake, sounds like he's gonna offer this for us after seeing mine.
I'll probably want a stock TBs since Steve isn't doing them anymore. 65mm I think he was porting them too correct?
I make a mounting bracket for the Intrepid fans. It holds the fans up in the radiator so the top is held in place by the factory tabs on the radiator top plate. I sell them direct on eBay and thru Kirbans and GBody.I second the trans parts. To my knowledge there is really only 1 person making those parts and stock is limited. I am considering making them personally as well. The forward and direct drums require that you use the original parts then cut out and weld in a stronger section which addresses the splines/shaft weakness. The stock output shaft can be duplicated as it is a weak component as well. It tends to snap where the shaft is tuned down.
Dual fan mounting brackets would be nice.
Throttle body repair service too.
I'm sure there are many other items we can use.
What equipment did your friend retain? This is kind of a nitch market. Tough to make money at it. Many of us have been fabricating parts for years to keep our cars going and or improve overall drivability. I hope you all come up with some excellent new products for us!!!
Yes, yes, yes very much need that..It seems he opened the throttle body to 62mm and with the half shaft mod it flowed the same as a 64mm or 65mm.
Awesome!! Wish I would have known that before I made my own. Happy with how they turned out but a lot of hours on a mill. Cut some and test fit then repeatI make a mounting bracket for the Intrepid fans. It holds the fans up in the radiator so the top is held in place by the factory tabs on the radiator top plate. I sell them direct on eBay and thru Kirbans and GBody.
Better flowing/design plenums, stock location intercooler necks, end tanks for aftermarket cores, shifter handles, billet fuel pump senders,
deep trans pans and pick-ups...
