Any cruise nights in fort lauderdale?
evil666
I'll be in Fort Lauderdale from May 31st to June 12 and was wondering if there will be any car events/cruise nights/shows during that time. Any info is greatly appreciated.
Thanks,
Marco
(Montreal, Quebec)
This is my new set-up: T-Top 86 Grand Nationals 109 block with weisco forged pistons and 2 billet center main caps, M&A aluminum heads, roller rockers, port match lower intake ,te63 a.r .82, erson 214/214 cam, razor alky injection, 94 octane, hooker cat back with dyno max ultra flow muffers, kenne bell headers, 60 lbs injectors, extender alky chip with 23/21 timing, with a gen 2 with a LS1 maf,thdp, mease 24 row IC, PTC 3200 stall 9 1/2 convertor, Ron Custom max boost brake module, MT drag radials (275/60/15) , rjc power plate, rjc boost controller, zeitronix wideband, HR motor mounts, Weld Drag Lites with skinnies up front, electric exhaust, hr rear sway bar, no front sway bar, 90/10 lakewood in the front and 50/50 lakewood shocks in the rear with energy suspension poly bushings all over, boxed rear lower control arms, Big mouth cold air with an AFE air filt
T-Top 86 Grand National 62000 km)
stock long block, stock suspension, 12 inch red stripe convertor (2800stall), te44, smc alk injection (95 % etanol), 25.5lbs boost,( boost spike 28 psi in 1st gear), 94 octane, hooker cat back with dyno max ultra flow muffers, 42 ½ lbs 009 injectors, turbotweak alky chip with 23/21 timing, thdp, mease 24 row IC, Ron Custom max boost brake module, MT drag radials (275/50/15) 3720lbs race weight with driver. (Torque convertor locked only after car shifted in third), rjc power plate, rjc boost controller, zeitronix wideband, HR motor mounts, comp cam 980 valve springs. Weld Drag Lites with skinnies up front, electric exhaust cut-out.
BEST E/T
60FT=1.53
1/8= 7.25
1/4= 11.48
MPH=120.82
BEST 60FT=1.52
I have a gen 2 with an extender chip and LS1 maf, hr rear sway bar, no front sway bar, 90/10 lakewood in the front and 50/50 lakewood shocks in the rear with energy suspension poly bushings all over, boxed rear lower control arms. MT 275/60/15 drag radials. Big mouth cold air with an AFE air filter. The times above were done with out these parts
tower shoppes
every friday night there is a big cruise at tower shops(a real big shopping plaza w/ a home depot,costco,etc.) I-595 and University Dr. about 5/7 miles west of ft.lauderdale airport. they have a dj playing oldies and a swapmeet/fleamarket area. 6pm/10pm.
look in the florida section. Miami has things going on, tower shops in lauderdale, and stuff happening in palm beach. The tower shops car show usually has several hundred cars every friday.
Thanks alot guys, I am leaving for florida tomorow and I will go check out the tower shops. I hope I will see some buicks.
Marco
(Montreal, Quebec)
BEST E/T
60FT=1.53
1/8= 7.25
1/4= 11.48
MPH=120.82
BEST 60FT=1.52
If i remember right the last friday night of the month is when the buick boys go to the towers shopping center,lots of hot rods, mustangs and other muscle cars.boy you will find it hot....LOL
MARCO,,,bring the wife on worth street in palm beach,it has all the top disigner boutiques and exotic cars
Back from Florida, just love it down there. Went to the tower shops twice but only got to see one GN, but at least I got to see some other nice cars. Bob I didn't get a chance to go on worth street, which is good because like in Claude's words, I got ruined enough as it is.
See you guys,
Marco
