Supercharged408
- Oct 28, 2001
Craig (or anyone else), I have a FAST that is setup to work with stock sensors that are also being used by the stock engine controller. I would like to run stand alone sensors, and I just wanted to know if this can be done without any mofication, or do I need to add pull up resistors for the sensors? I do this kind of electronics all the time, so if pull ups are neccessary, could you let me knwo what size the FAST likes to use and where on the board to solder them?
Thank you,
Damon
Thank you,
Damon
