U ulose2av6 Member Joined May 27, 2001 Oct 14, 2016 #1 does anyone have a diagram on how to plumb in factory transmission radiator cooler with an aux transmission cooler. is the bottom line the feed line and the top the return line. not quite sure if I missed up the loop. thank you.
G gusszgs Active Member Joined Dec 9, 2007 Oct 14, 2016 #2 http://www.gnttype.org/techarea/images/Cooler.JPG
J ~JM~ Wrinkled Member Joined Oct 31, 2007 Oct 14, 2016 #3 That picture doesn't look correct. The hot tranny fluid should flow into the bottom of the cooler & out the top on both coolers. Maybe I'm just looking at it wrong.
