This is a Barry Grant BG400 electric fuel pump pump rated at 400+ gph at 18 psi, is adjustable from 16 psi to 25 psi, and draws only 14 amps. It uses -10 AN inlet/outlet fittings. It is compatible with gasoline or alcohol, and is completely rebuildable.
Included is
BG400 fuel pump
BG5000 fuel filter
BG140019 pump to filter adapter
BG fuel pressure regulator
$250 shipped
