I just had my turbo off to replace my flange gasket....
During this I noticed oil caked up on the bottom of the turbo between both halves.....this usually indicating a bearing issue.
I checked my shaft play and sure enough it has some.....
I have had this turbo for 12 years or so...its an old dinosaur TE-66 but it works good and I have never had a complaint.
In that time it has had several bearing failures and it has been rebuilt by precision several time...the last time was about 3 years ago.
I have recently seen several post regarding a restrictor in the feed line and if that is not there it will cause premature bearing failure. With that being said I have an old school turbo saver on the car also.
Is the restrictor something I can visually inspect? I have never known about it or even thought about it????
Since I now have to have this thing built again, what is the general consensus on swapping the journal bearing to a BB?
Who have you guys used to do the swap and were you happy with the results?
