One more Photo different perspective
Just wanted to show one more photo of bearing cap from block. As one can see the coating and bronze surface are completely gone.
I am trying to problem solve and eliminate possible points for problems. I think cap alignment might be ok. Now I just need to fully understand how the transmission can play into this.
Balooned converter - I've had this checked it wasn't an issue.
Restricted trans cooler - not sure, I have a perma flow cooler with lines that are larger than the stock line I think -4 or -6. I need to understand how this might cause thrust failure.
Improperly installed torque converter - I did not shim or measure when I installed. I do know the hub of the converter was stuck in the crank. I had to pry it free. When operating does the torque converter actually move back and forth hence the name flex plate? The plate allows for this slight movement.
