stroked347
- Nov 10, 2001
lyon, i highly recommend Ed, he hooked me up with my AFR 205's and my solid roller cam.
Then go ahead and post youre combo so that I can prove you are Full of BS.Oh I forgot you won't because you know you will be proved wrong again.Originally posted by stroked347
Look at some NMRA factory stock class times..The E7's arent the only iron head jackass. Timeslips can only support a claim
stock bottom end 302's tend to blow up.....sounds like 5th grade and your wrong
you still have no clue as what the hell your talking about
You are proving my point perfectly you have e7s with port work done.Not alot maybe but work none the less and you are only putting 276 to the rear wheels and 317.4 from the flywheel.For a 13.31 second run.Originally posted by lyonsd
What about ported and polished E7s?
They guy (Chris Smith who worked at Dugan and then Atlanta Chassis Dyno and then that place out by Road Atlanta) who ported my E7s showed me a couple of cars at his shop that ran high 11s low 12s with ported E7s (no power adder). Mine have a light porting job (some bowl work, exhaust bump removed, slightly bigger valves) and I went 13.3 with them on street radials and no power adder.
But I think I'm going to get rid of them and replace them with an Ed Curtis package (AFR 165s and a cam).
Keep them comming You just keep on reenforcing my point.
You just about had me until this part of the post.A N/A car that has 310 rwhp in bad air has much more in good air at lower elevations.So you couldn't have made the runs with the same 310 RWHP. But thanks for participatingOriginally posted by Bob Cosby
It has gone as quick as 11.67 @ 3225 lbs (75 lbs under the weight referenced in preceding posts) with the same 310 RWHP on slicks and in good air (~ 200 ft above). BTW....this was most certainly with 7k rpm shifts - that is essentially stock redline on a DOHC 4.6.
Also gt40's and gt40p's with bigger valves made by frpp are not stock mustang heads.
Totally irrelevant to this discussion. The issue was aluminum vs iron.That's like me bolting on a set of frpp scj heads on my big block ford in a truck and saying that it has stock heads.What a laugh.
You should read more closely. I "freely admit" that I spin my DOHC 4.6 to 7000 rpm (not rpms - revolutions per minutes).Also you freely admit trhat the guys are spinning 7000 rpms.
Correct - and they do NOT spin to 7000 rpm with the stock cams - nor did I say they did. Go back and read again - closer this time.WE were talking about 5.0 engines not mod engines but what the hey.
Better yet, I'll tell you that they are not running 7000 rpm at all.Now tell me that the 5.0 based engines arn't running a girdle at 7000.
Thank you. The most sincere compliment is when someone says "I don't believe you". Would you like references?Youre hp has either changed or you are in no way running 310 and running 12.02.
See my post above. You might want to be careful laughing when you really have little clue what you're talking about.I suppose that the track had the same elevation humidity and pressure as the dyno?LOL
Tell me...how do you tune a car without a distributer, without an adjustable FPR, and with no ability to change computer input parameters at the track? Rhetorical question, of course. My car was tuned on the dyno by Jimmy LaRocca using Autologic software. When I go to the track I change tires and run.Also you probibly did no tuneing at the track right?
Ya. Have a good time at work.I wish I had the time to address youre post more right now but work await's me.
What part of I have to go to work did you not understand?? MAybee III shoould HAAAVE SAAAID ITTT MOOORE SLOOWWLLLYYY SO YOUUU WOULDDD UNDERSTANDDDD.IIII HADDD TOOO GO TOOO WORKKKKK!!!Originally posted by Bob Cosby
Did you chose to ignore the other info I provided?
I'm sorry....you just picked a few certain items that you thought you could make valid points on. My bust.What part of I have to go to work did you not understand?? MAybee III shoould HAAAVE SAAAID ITTT MOOORE SLOOWWLLLYYY SO YOUUU WOULDDD UNDERSTANDDDD.IIII HADDD TOOO GO TOOO WORKKKKK!!!
Speaking of dense....buddy... I never said they were stock. I said they were iron. You said they did not use iron. I showed you the rules and proved you wrong. Now you are harping on "stock" or "not stock". Nobody is argueing this but you. They are production GT40 heads (93/94/95 OEM Cobra heads or GT40P's from 5.0 Explorers), usually with non-stock valves.Once again you are wrong cast iron heads that are made by frpp are not stock heads(they never came on the cars that are running them) they may be allowed by the rules but that doesn't make them stock!!
Translation: I do not know what I'm talking about, but I'm trying to make it sound good.By the way SAE is a correction factor no more no less.The car can put out more or less based upon pressure and relative humidity.
I agree that none are the same, and also that the numbers aren't absolute. However, this is somewhere else that you don't want to go.No chassis dyno is the same I can take the same car and dyno it on two different dynos in the same town an hour apart and get two different #s so to pretend that this is a absolute # is incorrect.
I see. So increasing the rotating weight of the driveline does not affect HP? Wow - I'll let my racing buddy's know this....amazing how we spend money on aluminum driveshafts, aluminum spools, aluminum flywheels, lightweight rods, etc, when that really doesn't make much difference. Why don't you go out and put a 50 lb driveshaft on your car and see how it likes it? Got physics?Incorrect: The difference between a locker and a TL has very little to do with it.You gain or lose more power with a different backlash or a change in gear oil then the little bit of difference in wieght.
Where are you getting all these references to "stock"? I'm not argueing ANYTHING about "stock" this or "stock" that. Who cares? What I'm correcting you on is several points. I'd type them slower, but I don't think it would help. However, I'm specifically talking about...Ok ford made scj cast iron heads.Would a correct statment be My truck engine is stock.If it was a 460 with cast iron scj heads since they never came on it??
Correct, it is not stock.In my opinion its the same as saying my mustang never came with these heads but because they are made by ford and are cast iron then when I bolt them on I can go around saying I am running a stock car.If someone is bolting different heads on a car that it didn't come with.It is not stock!!!
BS. Your post(s) said that they weren't using cast iron heads. They are.My post said this.
Does this mean that you "finally" looked at the rules and have decided that F/S cars don't have aluminum heads?By the way stroked you mentioned factory stock.If you ever looked into the rules or looked at one of the cars they are anything but stock.
Stupid statement.So you consider a mustang that can wiegh 300 lbs less then the factory made them at and has heads that never came on that car stock??
I'm good friends with both them, and have raced with both of them for 3 years. Perhaps you would like to invite them to join us? I'm game.Better tell Mike Washington and tim duncan that!They freely admit to spinning there cars to more then 6200 rpm.
Thank you for your consideration, but I don't need an "out".Also bBOB the laws of physics will change for no man so I was giving you an out by trying to let you find some reason why youre car could have had more power on a given day then another.Which sometimes happens.
Look up. Also, I'm sorry that it takes you so much HP to go 12.2. It must really suck.But if you think the laws of physics will change just because of you or some other racers want them to then continue to delude youreself.
I'll take what's behind curtain C, Monty.Youre car was either making more power due to humidity etc or you did not run the number.Youre choice!!!
