2hp, with the dump closed. Open Exhaust Is huge
Yep. Totally stock exhaust. It's got to go!
We didn't change the boost....
yea .. but your data file says otherwise
Granted...the boost was not very steady, but both log files with the dump open saw 30.8psi and 30.9psi respectively....I'd say the boost really didn't change.Wonder how much more the E85 setup would have made if the boost was the same ?
The 100 octane with the dump closed hovered around 27psi max....and the e85 with the dump closed hovered around 26psi....yet it made slightly more hp.
It is possible. It has a 3bar MAP sensor.Is the map sensor maxxed at 30.whatever boost?
Why wouldn't a 3-bar be able to read more than 30.x?
3-bar converts to about 45 psi I thought
I consider myself schooled now. We all gotta learn somehow.The first 100 kPa (1 bar) is negative pressure. That leaves 2 bar or 29.01 psi. Sounds like the MAP sensor was maxed out. The data doesn't mean anything at that point. If you own a turbo charged car you should know this.
I just hate to hear about someone blowing a head gasket, or worse, because they don't know the basics. Sorry for my words, did mean to put anybody down.
Unfortunately this is usually what it takes for people to learn .. until they see it with their own eyes ... they don't believe
