Best high temp exhaust sealer?
J Banning
Quench my thirst with C16
What is the best high temp exhaust sealer? I'm tracking down an exhaust leak (headers, turbo, crossover, etc.) and before putting it all back together I will clean all surfaces and then apply a thin coat of sealer to ensure a good seal.
I've seen the Permatex Copper sealer, but was wondering if there was anything else out there. Preferably something that I can find readily at a store.
I plan to let the car sit overnight before starting it, but aside from that are there any recommendations?
Thanks,
-Banning.
I've had good luck with the Permatex Ultracopper sealer. Haven't tried anything else and it's easily available.
Permatex Ultracopper sealer, I used on my driver's side exaust manifold and crossover and no leaks yet.
Nickle-based antiseize. Worked good on the turbine/header/elbow connections for me.
Discount Auto Parts has a stainless steel liquid exhaust sealer. Works good for cracks in manifolds..... I use it as as a joint sealer. It has never blown out on any joint that I've used it on.
