I have bilstien shocks. Today I noticed I had some oil on my garage floor under the rear tire area. I found tat my rear shock is leaking. Has only about 1,400 miles on it. Anyhow i need to order another one and replace the bad one. The shop did the initial install. Whats the best way to change a rear shock? Should i jack up the car? When I realease the shock will the rear fall and spring pop out?
Thanks again
Thanks again
