Blazer Brake setup - Issues with passenger side caliper sticking
Danster
Senior Member
Hey guys need some direction as to what may be causing for the caliper to not retract enough to prevent the pads from rubbing against the rotor?
I even tried a used caliper from the auto parts just to eliminate the caliper I purchased? Drivers side is ok but the passenger side is giving me the problem.
I did do a Hydroboost conversion a while back and it was working fine with the stock brakes.
What can I do to troubleshoot this issue?
Appreciate your suggestions, TIA!
Dannyo
brake hose.
corroded/sticky sliders that don't allow the caliper to float.
pinched brake hardline under the engine- i've seen them flattened by people dropping engines on them when doing installs before.
