mwolfe1969
- Oct 26, 2005
I bought a used PTE front mount intercooler, my question is do you have to use a blowoff valve. What are some off the advantages or disadvantages of using one, driveability, etc. Thanks.
SignUp Now!Personally I would use it. As stated above They are normally used for standard shift cars. Here is why I use one. When I am turning 6000 rpm and only God knows how fast the turbo is spinning, I let off the gas and hit the brakes, that compressed air has got to go somewhere. It is forced back through the turbo. I don't care what anyone says, THAT CAN'T BE GOOD ON THE TURBO'S BEARINGS! My turbo was $750 dollars and that was cheap, but I still don't care to replace it too soon!
Yup, a lot of guys try to live by the rule "if Buick didn't put one on from the factory then I don't need it", but let's face it, we put a LOT of stuff on these cars that Buick never did themselves, so that rule goes out the window. Just because some guys can run a turbo for years with no BOV and say it still runs good doesn't mean that there isn't a benefit to having one.
Any pictures of that HKS bov? Did you mount it to the up pipe?
Here it is mounted on the uppipe...
Only downside is that I recently noticed my engine only pulls about 12" vacuum and it's possible that the vac leak may be related to this because I can't think of anything else. But I will try to hunt it down soon as maybe there's a leak somewhere else...
BOV is not needed on these cars.
Save your money, the "benefits" seem to apply to the manual transmission 4 cyl imports, this reasoning has infected the new comers to the TR world.
Its just a shame to see junk science, seperate people from their money.
Venting a blowoff valve to atmosphere after the MAF will cause the engine to rich very rich until the turbo winds down.
If you have a BOV mounted in the up pipe it's best to let it vent back in between the MAF and turbo inlet.
Is there a bolt that you can tighten and loosen to adjust how tight the valve is? If there is loosen the nut you would to adjust it and put some teflon tape behind the nut and then tighten it back down. I have a HKS bypass valve on my buick and it leaked until I put the tape on it then no more vacuum leak from there.
EDIT: I take that back. I can see his MAF is on the inlet side of the turbo. Oops.
Jim
Furthermore, of all the automotive turbo applications Porsche, Audi, GM, Ford, Toyota, Nissan, Dodge, Mercedes, BMW.
Of all the Heavy duty applictions International/Navistar, Cummins, Mack, Cat, DetroitDiesel, Mercedes, etc. None were offered with a "BOV".
Why? Its simply not needed, the original design of the CRHA's fully floating bearings with oiling provisions, and the newer ball bearings are able to function in either direction and provide support, because they were designed to function in a severe enviroment.
Once again look at the above manufacturers and see how many did come with manual transmissions and do not have bovs.
