May 15, 2014 #1 W wooooof Member Joined Dec 16, 2011 Messages 99 My heat/ac blower only works on high speed. any suggestions?
May 15, 2014 #2 P phil_jordan Active Member Joined Aug 22, 2012 Messages 460 Try this http://ihadav8.com/forum/VortexBuicks/acvacuumswitch.htm
May 15, 2014 #3 P phil_jordan Active Member Joined Aug 22, 2012 Messages 460 This was the first thing that came to mind when I read your issue. HTH!!
May 15, 2014 #4 G GNVenom Well-Known Member Joined Jan 6, 2002 Messages 2,082 Do you have the digital climate control option? Or is it the manual heat temp controls?
May 15, 2014 #5 W wooooof Member Joined Dec 16, 2011 Messages 99 It is manual Posted from the TurboBuick.Com mobile app
May 15, 2014 #6 R RmvBfrFlght Well-Known Member Joined Sep 28, 2007 Messages 2,234 wooooof said: My heat/ac blower only works on high speed. any suggestions? Click to expand... Most likely the resistor unit is bad. It is located on the top of the HVAC box under the hood. The resistor controls the various blower motor speeds. RemoveBeforeFlight
May 15, 2014 #7 W wooooof Member Joined Dec 16, 2011 Messages 99 I have already replaced the resistor. That's not it Posted from the TurboBuick.Com mobile app
