Just an idae, but doesn't the Bosst Commander from Mike Light have an input that will lower boost? I know some people hook it to the 3rd gear switch, but couldn't it be hooked to a low alky light signal so when the alky is low boost gets scaled back 6# or so?
rolling around the street that might be fine , but nearly every time i launch with moderate 1.6s the alky low level goes on regardless of whats in the tank , and at launch or there after is not when i want things pulling my timing or boost or what have you , i think razor pointed this out early in the previous post before i could post it .
this has been stated in past posts but here goes again , there are so many "what ifs" conditionary failsafes that you could dream up to failsafe your alky system but youll never encompass all posibiliteis and youve also dramatically increased the cost . alky is just one item in a long list of things that has to work flawlessly to make a clean run and still have a motor left to drive home with , you are probably more likely to have a fuelpump or regulator failure which is potentially just as catostraphic , or a powermaster failure going out to 7-11 which could ruin your month , or have a tire blow out or an axle break and roll out , or have your lugs snap off , or have your shock go through your tire (it has happened) ,or have a tie rod break , or a ball joint
old line KISS "keep it simple stupit" , razor beleives this (i think he does) and that cuts down the possible areas for failure . if you feel the current kits arent safe enough try your ideas on your car and let me know how it works , I like tinkering and have a couple dozen ideas but know of so many ways things can fail i would be under the hood 24-7 (i'm the pesimist that looks at things and sees the possible failure).
now matter how hard you try ,sh## happens. ive run the tank dry and at boost levels that most alky users wouldnt dare to go and it still runs . how can this be ?? well , I run an audible knock (caspers) , when it goes off you cant help but lift , faster than any sensor or scanner that you dont have time to watch .
even with the low light off if you have a low tank you can run out of alky on a run (been there
) , you can also run out of fuel if you make a pass with less than 1/4 tank, (been there too :biggrin: )
any of these could have been catostrophic but it still lives .
bottom line, you are pushing a vehicle , a small six no less thats in a car built for your grandpa , to extremes that v8s only dream of and its up to you to know your car (both mechanical and tune limits) and do all you can to ensure it's longevity . you should get in the habit of checking your alky reservior , along with your oil and antifreeze and tire pressure and the list goes on and on...
