TurboChris87
NCSU Go Pack!
- May 25, 2001
Finally got my amp....won it on E-bay in sep. Anyway...I've mounted it where the spare tire goes. With the trunk kit I can hide it 100%. Two questions though. There is a body ground back there for the frame housing. Can I Ziz wheel off me a clean place on it and it be a suitible ground? Or should I drill a hole and run the wire to the frame below?My co-worker says that the body ground will be fine. Just wanted to ask you guys first. Two: Will the space the amp will sit in be suitible for heat disipation when I cover it with the cardboard piece that is molded to fit over the spare tire?
