Bolt Patterns?
VKREGAL
Whats the bolt pattern on an 84 regal? Im looking at buying american racing rims that are on an s10. anyone know if they would match up without a problem? Thanks
I believe the bolt pattern is the same.The back spacing is what you want to know.If you know the person selling them see if they will let you install them on your car and see what they look like.good luck
to be honest i don't understand the whole back spacing thing, but i know the wheels are the same height and width as my stock wheels so does that mean anything?
they will likely be the same. as far as back space goes, in short, a larger measurment will be how far the wheel has the sucked in look and a shallower measurement will be how far it is to the fender lip. you gotta know it or else you'll get wheels that hit something on the inside or vice versa.
to find the back space take a straight edge and lay in across the back of the rim and measure up from the center of hub. look for 3-4 inches to be safe.
