I've been having a boost control problem for a while now and would like to fix it. When ever I floor it the boost spikes for a second or so maybe 2-3psi over what its set for after a second or two it settles back down. If you stay in throttle for an extended period (10 plus seconds) the boost will start to creep higher and higher. My car has a 49 with a garret housing that does have the enlarged wastegate hole(by limit enginerring). I have no aftermarket wastegate mangement.
