boost fluttering
ulose2av6
when i lay into the throttle, there seems to be premature boost blowing off like i am getting off the gas. I cant punch it without the boost fluttering.
Probably need to port the wastegate hole. Exhaust pressure may be breaching the seal. (overcoming the wastegate spring)
My 6131 did that.
If it's around 10-15 pounds and then it cleares up with higher boost it's compressor surge. Can be caused by a mulitude of things, search "compressor surge" and read away!
