boost gauge wiring on instrument clauster
89TURBOTA
does anyone know where the two wires that go to the stock boost gauge on the instrument clauster go connected on the clauster
thanks
robert
My guess is to the MAP sensor under the hood.
May not be a lot of help....But I blew the hose of my MAP and my boost guage stopped working.
I have the same problem! I took my tach out to have MacEwen make the template for the white face gauges. My tach was gone for a while, and I lost the diagram I made. I tried a few things.. but I couldn't figure it out, so I just baught an autometer boost/vacuum gauge and put in the 3 gauge POD on the a pillar. Looks great, everything is whiteface now. Good luck with that wiring, i couldn't figure it out!
~Murt
TTA #750
Robert, the light green wire goes from the gauge to the MAP sensor and the Black wire ends at a connector near the ECM.
I have a couple dozen of the Boost gauge wire harnesses if you need one.
thanks john, the problem is i have the two wires disconnected from the instrument clauster, do you know to what terminals do they go connected on the back of the instrument clauster
thanks
