1 19BuickGN87 Member Joined Dec 4, 2006 Aug 29, 2016 #1 How accurate are boost numbers using scanmaster and power logger?
M mikestertwo Well-Known Member Joined Sep 13, 2006 Aug 29, 2016 #2 Only as accurate as the map sensor you are using to measure the pressure.
1 19BuickGN87 Member Joined Dec 4, 2006 Aug 29, 2016 #3 mikestertwo said: Only as accurate as the map sensor you are using to measure the pressure. Click to expand... OK I'm using a 3bar ,boost gauge reads 25psi scanmaster shows 26.9psi
