Turbo v8 guys,how do you determine a safe boost at the track without a knock detector, for different octane gas?
If you know what HP you make on an engine dyno, and your not set up with a knock detector how do you come to know what's safe?
Can one assume 10 lbs is safe on 90 octane or 100 octane, and anything 15 lbs and over requires 116 octane.
Why spend 14 bucks a gallon if your not going to use maximum HP on runs.
will a dyno run in street trim tell you what's safe?
Do any of you Turbo V8 guys run 92 or 100 octane at the track?
