TurboNoong
- Oct 2, 2003
Originally posted by TurboNoong
http://www.jscspeed.com/wrx/cooling/dei_cry02.htm
Have you seen this kit?
Originally posted by TurboSlacker
Okay, Frank.
Let's be clear here. Are you challenging me for ET or MPH? I'm not currently building up my street GN to run with drag radials or slicks at the track and bust out a bitchin ET. Instead, I'm targeting your original GN goal of 110mph, but I'm trying to do it with a stock turbo and intercooler (bigger ain't always better)
Either way, it should be fun!
SINISTR GN update:
Alky pump has a clean bill of health per Steve Chlupsa. Alky tank is re-installed. Cold-air kit is now installed (very nice peice from Mark Hueffman). Fixed header is back on. In-car boost controller is in.
Ready to start tuning once we get a dry weekend, and I'm over this damned cold I've been fighting for a week now.
I'm going to try out the 100 octane Thrasher with stock injectors one more time just to see if the repairs and upgrades helped reduce the knock I was experiencing. Then later on, I'm going to put in the 37# Delphi injectors and get an alky chip burned for my combo and start fine tuning.
What do you mean? It's still stock
Stock turbo, stock intercooler, stock headers and crossover pipe, stock throttle, stock plenum, stock intake, stock heads, stock block, stock tranny, stock torque convertor, stock gas tank, stock fuel lines, stock fuel rail, stock ECM, stock MAF, stock seats, stock dash, stock headliner, stock trunck carpet, stock t-top bags, stock drivers manual...on and on!
It just has a few little tweeks to make it look a little nicer, that's all
Originally posted by inzanesrt4
I have seen that system before installed on awd talon gained 20 or so HP probably more gains while blasting down track with front mount then sitting on dyno. He installed it in july 2003 I havent seen him since so I have no Idea about how it has lasted or any side effects. He said system was pretty easy to install and cheaper than the NOS set up he was going to get cheaper to fill up I guess to.
Off Topic:...Boost Have you checked out Worldoneperformance.com
They are great people to deal with and have great prices on wrx and sti stuff. Even SRT-4 and Evo stuff now. They are also located in Seattle.
