I have the following parts for sale I'm bringing to the BPG meet in Columbus, OH July 30th
I will be attending Saturday only.
TH400 Stage II RMVB, Brake, new never ran - $1,800
Manual Reverse Shift Pattern
Pro Trans Brake
Media Blast Case Prep for Racing
Hytuff Input Shaft
CNC Forward Drum for Exclusive Shaft Retaining System
Intermediate Snap Ring Case Support
Clutch Hub Rollerised
2.48 Rollerised Gear Set
Rear Case Torrington Thrust Bearing
Torsional Mains Shaft
Harden Stator Support
H.D. 34 Element Sprag
Tube Shaft Modification (Keeps Direct Drum Parallel Extends HP Capacity of Sprag)
Low Drag Option
Tensioned Sealing Rings
High Energy Expanded Capacity Cutch Packs
ARP Stainless Fasteners
Deep Pan
Hi Flow Filter Assembly
87 Dash Board, complete w/surround. Beautiful shape - $100
Rear Seat Set, bottom is nice, back has cracks at top - $50
Various T-Top (gray) Interior parts - $40/lot
Seat Belt Set, Gray,Complete w/bolts - $40
Lower Door Panels, 1 set GN, 1 set T-Type, both Non-CSII - $40/set
Sill plate set - $25
Headers - TA Style - Knock offs, deburred/slagged - $150
Connecting Rods, stock - $60
Valve Springs,Comp Cams 980-12,brand new - $40
Black Out window Trim - T-Top - complete minus drivers drip - $60
Front chrome Bumper, complete w/prkng lenses/black trim - $50
Rear GN black Bumper, complete - $50
Rear Cast iron drums, never turned - $10/set
Front Rotors, never turned, nice - $10/set
If you see something you want please PM me.
Thanks!
Pro Trans Brake
Hytuff Input Shaft
Low Drag Option
Deep Pan
Thanks!
