Brake hoses for Blazer brake conversion
Chevman2448
Im am doing a Blazer brake conversion on my GN. Ive heard conflicting information on which hoses to use when doing the conversion. I am sticking with SS hoses. Do I use GN SS brake lines or do I go with Blazer/S10 2wd brake lines? When I found G-body SS hoses on ebay it said they were designed to be used with OEM calipers.
Stock style replacement hoses. Look on amazon for Russel part number 692100 and they should work fine.;) You may have to modify the bracket on the frame that holds the steel line to the hose for better fitment though.
Thanks I got it all figured out. I got the hoses off ebay from inline tube. Though the OEM style hoses will bolt on and work just fine for this conversion. No new hoses are needed if yours are in good condition.
