rookie_LC2
the name is...DOOmass
- Dec 31, 2003
welp, i finally had the time today to (almost) finish the entire braking system. the original line decided to leak not 10 minutes after i replaced the fuel feed line...luckily it was while sitting on the lift.
everything is on the car, including new Bendix hoses, calipers, and rear cylinders; pads n rotors n shoes n drums, with new bleeder valves in rear. I picked up a stainless-line kit from Inline-Tube (it ALMOST fit! two hours later...looks good once its in), with a new brass proportioning valve also from Inline.
I also swapped out the old powermaster and a vacuum booster sits in its place, pedal is in, switches are in, TTA vacuum block hooked up, with a new check valve on the booster. anything im forgetting?
anything else i need to look out for tomorrow when i finish up? the car is gravity-bleeding right now, with the right rear bleeder valve open.
any other tips on properly filling and bleeding?
also, not trying to re-hash the old "Powermaster vs. vacuum" booster discussion again, but should i really worry about lack-of-vacuum for the booster? i've heard, read, (also searched) conflicts of both, just wondering...opinions?
also, i was told that there is a vacuum reserve tank or something on these cars for the cruise control. is this true, and is it solely for cruise control or does it affect all other components underhood...and does it have a maintenance schedule! I dont wanna forget anything
thanks! ...for reading my long ass post. damn thats long.
