brake lines
CHANCE
No longer a Buick guy!!!!!!!!!!!!!
hey guys my brake line that runs along the fram to the rear of the car busted today were can i get a replacement at
I had to replace mine and used a 60" piece + a 30" piece along with a brass coupler. This will get you almost to the prop valve. NAPA sells an adapter hose that screws right into the prop valve to connect to the other two pieces with another coupler. There is one clamp you won't be able to get to that's sandwiched between the body and the frame way up front. Outside of that, fish your old one out and bend the new ones to match, then just reinstall and bleed. It's a few hours work but not bad at all.
