Brake upgrade?
Discussion in '3800 Supercharged Tech' started by mikewest_08, Mar 19, 2017.
  1. mikewest_08
    mikewest_08
    Expand Collapse
    Sep 8, 2012
    116
    4
    Offline
    I have a 1999 gs and I want to do front and rear brake upgrades on it. Can anyone give me any info, on what kinda of cars I can get parts off of. Also if I upgrade both front and rear will the system produce enough pressure to stop the car?
  2. TABuickMike
    TABuickMike
    Expand Collapse
    Michael Tomaszewski Jr
    Jan 28, 2009
    85
    2
    Offline
    F-body brakes are a popular upgrade for the W-body cars. You can swap over the rotors and calipers, and get a shim to use the f-body banjo bolt I believe, or tap the caliper bracket for the f-body bolt. You can also swap the brakes from like a 2006 Impala I believe. Both instances use a larger 12" rotor so they have more stopping power. If you look on some of the pontiac GTP forums, there's write ups on how to do the swap.
Share This Page
