Brf transmission, rjc torque brace, alum. Crk. Pulley, much more!
BLACK MAGIC RACING
formerly turbo_canuck
I have some items for sale;
-Rebuilt Brf trans, stock rebuild with shift kit and 12" 2800 stall, got in a trade. Not much mileage on it. $900
-rjc rear engine brace, notched for brake line.-$75
-Rjc under drive aluminum crank pulley - $35
- set of 120lb racetronix injectors, only ran about 15 total mins. -$300
-5.3 gm engine from a wrecked 2002 sierra with 125,000 km. Has steel head gaskets, head studs, and a stock ls1 cam, 60lb injectors, and billet fuel rails. Otherwise all stock. Set up with manifolds modified for turbo. Comes with main harness for F.A.S.T. Xfi ecm, .F.A.S.T. XIM box with harness, and adjustable motor mounts for gm g-body. Ran 9.40 @ 137 with a 78mm turbo in a buick regal. Just add turbo, xfi box and go!
$2000
- new gears for ford 9" 1.31" pinion, 28 spline. 4.11 gears. $100
Engine and trans can only be local pickup, or can deliver to bg. Everything else is plus actual shipping from J0L-1B0 Quebec, canada. Thanks!
Interested in the rjc crank pulley. Condition? Cracks? More pics?
Thanks.
