Flyin Brian
- Jun 18, 2011
I agree. If you wanted to get scientific about it you could take it to a metallurgist and get some tests run but that would be expensive unless you know one. If you knew someone with a hardness tester you could check the hardness in the discolored area versus the rest of the crank. It would be interesting to see if the heat effected area was harder or softer than the rest of the crank. In any case I would not re-use a part that was discolored that bad.
