The instructions that came with my new BstC Boost Controller are pretty weak when it comes to explaining how to setup the 3rd gear scaling (discrete). I haven't installed it yet, but I thought I would see what you guys are doing to set it up.
This is going on my 87 Gn BTW....TA49 w/standard WG actuator...ported elbow w/larger puck... 2 3/4" downpipe...I got the dual WG solenoid setup too.
I understand the TPS trigger. I should be able to set the BstC turn on point by simply watching the scanmaster tps volts and seeing when the BstC light comes on. What is a good tps voltage to try first?
What about the other potentiometer setting on the back. Is it a percent scaleback from the overall knob setting? i.e. If I have the front knob set to give me 19 psi...then the 3rd gear switch comes on...does it scale it back a certain percent based on the pot position? If so what is the "full scale pull back" on the pot?
Is it 0-100 percent scale back? 0-50 percent? All the way counter clockwise is zero and all the way clockwise is ???? Or do I just have to play with it and see what it does.
Any help would be appreciated.
Thanks,
John
Thanks,
John
