HellOnWheels
HellOnWheels
- Feb 3, 2002
Guys, need help...again....
I'm trying to install a BstcCommand controller and I've ran into some problems.
Instructions reads C1-10 is a BLACK/WHITE wire at the ECM pin connector. However, pin connector C1-10 wire is YELLOW!
Instructions reads C1-3 is a PURPLE WHITE wire at the ECM. However, pin connector C1-13 is GREEN/BLACK!
Instructions reads C1-7 is a GREEN/WHITE wire at the ECM.
However, pin connector C-7 is GREEN/WHITE.
Instructions read C2-6 is a PINK/BLACK wire at the ECM.
However, pin connector C2-6 is BLUE/BLACK.
Also at C2-6.....what does the "2" suppose to indicate??...when all the rest is indicated as "C1".
I got the above Bstc Command information from Ramchargers.com site.
Thanks,
HOW
Thanks,
HOW
