Buick part sell now to fund the LS2!!!
Kid Turbine
Well car didn't sell so its Buick part sell now to fund the LS2!!!
stock 109 block $300
stock gm heads $150
stock turbo crank $150
stock turbo rods $120
stock valve covers $40
stock front cover $60
stock oil pan $20
Or can be bought complete for $750 already on crate for shipping also!!!
MSD DIS-4 with interface $500
Accel DFI6 ecm and adapter harness $300
(2) two stock incoolers $75 each
(2) gn stock turbos $150 together
some misc brackets ?
Okay now for the built engine setup!!!
4.1 non stage block 257 c.i. motor (torqueplate bored and linehoned) $450
Jack Cotton CPT-61 Turbo $750
stock manifold rebraced and welded $100
custom turbo filtering system $100
Sealed power Hyper pistons (4.005") 8.7:1 comp. $150
Reconditioned 2 dot rods $200
Reconditioned 10/10 Turbo crank $200
Upgraded GN Heads with LT1 springs $175
Felpro 1000 head gaskets (free with heads)
MSD 50lb injectors $300
Stock balancer $40
Stock flywheel $40
Stock oil pan $20
Stock coil, wires and module (new) $100
Stock upper and lower intake with Phelum Power plate and fuel rails and ing. bracket and throttle body$400
Comp Cams 212/212 camshaft and lifters $100
stock ecm with Turbo Tweak chip for build $150
Front mounted intercooler $200
in car now running but before part out big items have to sell first or buy complete for $2500
If buy either complete engine I will work with you also!!!!
Here is the list I have by pm or by post so far!!
9secvsix - 4.1 block
jdpolzin - Cam/lifters, TB/phelum
daves87gn - filter system
trans damm - front mount
cml87type - front mount
pm's sent and picstures will be uploaded soon!!
okay 9secvsix is off the list for the block (cause he needs a block capable of 4.020 bore stage 1 or 2)
And I just got a trade offer on the car, so we have to hold off for now guys, but will relay info as it happens, just hold on guys and thanks for everything!!!!!
Ill take the turbos as long as they are not trashed. By being trashed i mean the wheels have hit the housings. Ill also take the balancer
stock oil pan $20,, interested, how muched shipped to 60639.
Okay guys, for the ones I haven't contacted by pm's and that don't know, the car partout has been put on hold. Because the day I posted partout list I was contacted with a trade for a 92 Typhoon with extras for my car and extras.
