Burning Oil bad! Help!
  • Thread starter Thread starter jmvicp
  • Start date Start date
J
jmvicp
Guest
My GN has been blowing smoke out of the exhaust for awhile now, my water pump blew out a few weeks ago and my car overheated. I got the water pump fixed, but im afraid that when it overheated, it could have possibly blown a head gasket or did something to the engine. When i rev high, after about 2 or 3 revs, huge clouds of smoke pour out of the exhaust. I noticed tonight at the Taco Bell drive thru, that a little bit of smoke was coming from under the hood it looked like. Can you guys help me out, have you had a similar problem like this?
Joe
If its coming from under the hood check and see if you get puffs of smoke out of oil filler when cap is off? Also check under the car and see if the rear main is dripping oil on the crossover pipe .. the usual rear main blues..., and then next .. is your turbo bad and dumping oil in exhaust.
